What is this sound on Mercruiser 4.3, Alpha One?
larryarnaud
I have a rattle that is coming from somewhere around the bell housing. It only is there during idle. It goes away when throttling it, even just pushing a little on the throttle. Here's the sound:
  • Boat rattle sound.mp4
alldodge
Plug wire arcing, exhaust flapper, maybe flywheel dust shield is loose
Lou C
best way to tell is get a mechanic's stethoscope, I found a noise using mine that sounded like an engine knock coming from a rubber covered flapper on my Cobra...drove me crazy after my top end rebuild till I found it.....thing was I had to change to a different exhaust design at the same time (OMC one piece batwing to 2 piece manifold/elbow) which I guess changed how the water flows into the Y pipe....
Lou C
Perhaps that tin cover over the bottom of the flywheel housing is loose & vibrating…
