What is this Tube
76SeaRay
I picked up a used rack and pinion steering cable and steering column/shaft to replace my OMC steering to go to Mercruiser. Can anyone tell me what this plastic tube is used for on the side of the steering shaft?
Thanks.
southkogs
Isn't that the tension/friction adjustment? Or am I seeing it wrong?
76SeaRay
Thanks, that's not something that crossed my mind... I will go back and look at it again to see if it is an adjustment. Thanks.
76SeaRay
Well, I looked at it more closely tonight. No adjustment screw but there are threads inside the tube. Guessing there is a thumb screw missing from the assembly..
