What is this weird ticking noise coming from my engine?
samocamo123
It seems to be more noticeable when the engine has been running for a while and it doesn't seem to speed up when I rev up the boat. What do you think it could be? I have a 1986 Ebbtide Montego 170 with a 1985 Stringer 400 3L Engine (302STHRCOM). Also what would be the best (cheap) prop for my boat? I would like to be able to tube and ski but I don't want to have to sacrifice too much top speed.
frobotz
get a screwdriver and hold the handle to your ear. Move it around on the motor touching the other (pointy end) to hard non moving parts on the motor. Sound travels better thru solids. it will help you find the source of the noise.
EchoNovember
Can you upload a video of it making the sound so we can hear it?
My guess off the description is a lifter tick or a valve. Running a can of Seafoam through the tank should help dissolve deposits that might be causing that sound. However, without a video with clear sound, it's only guesswork and we'll be hard pressed to tell you for sure.
For propellers, check out iBoats propeller selection. Aluminum is cheaper than Stainless Steel, but you want SS for saltwater if that's where you'll be running it. There is also a lot of good info on propeller design. I am not a propeller expert, so I am not terribly qualified to give much of an opinion on them.
EchoNovember
That is an awesome trick!
best cheap prop is going to be a 17p stainless prop from craigslist. look for an original OMC stainless prop as used on a V4 Johnson/Evenrude. I used 3 props on my boat with a 3.0 / stringer. a 15p for slalom skiing and trolling slow, a 17p for tubing and a 19p for cruising
check your timing. you could be too far advanced and the ticking could be detonation. you could also be running hot.
