What is this??
brad614
This is mounted on the transom of my 86 Sea Ray, just to the left and slightly above the outdrive. Unfortunately, I can't see the back of it inside the boat without removing a lot of brackets, wires, cables, etc. Anyone have any idea??
Re: What is this??
Nope, not a doo-hickey. Looks like a fitting for passing either fish-finder transducer cable or speedometer tubing through the transom. However, at least in these photos, it looks like it's mounted kind of low.
skargo
Banned
Re: What is this??
It look almost identical to the fitting my line for my drive oil reservoir passes through.
xeddog
Re: What is this??
Can you see what it is connected to on the inside?
Wayne
boltonranger
Re: What is this??
I'm thinking it's a thru-hull fitting for the speedometer pitot tube.
Mine looks like that but it's stainless not black
-br
tswiczko
Master Chief Petty Officer
Re: What is this??
It's doo-hickey :rolleyes:
Nope, Definately a Thing-a-ma-bob.:eek:
If what ever it went to has been abandoned then remove and seal up with some gel-coat repair and forget about it.
unless you want to reactivate it(whatever it was that it went to)
Good Luck:D
bassman284
Re: What is this??
Good Luck:D
Well, I'm no expert but it definitely looks like a doomaflatchey to me. Could be wrong.
EddiePetty
Re: What is this??
....it's darn hear identical to our Garmin GPS/Fishfinder thru-hull cable shield. What worries me is how low it is mounted and that tell-tale tanic color stain beneath it. Personally, I would remove it and take a core sample from the screw hole in the transom. :)
Don S
Re: What is this??
It's the thru hull fitting for the round gear lube reservoir. Item #16 in the picture below.
skargo
Banned
Re: What is this??
Yes!
BTW, mine is slightly different, I have a screw top and bottom, but it's otherwise the same.
Tp the OP, it's obviously not in use, I would make sure it's watertight.
You can see mine, to the left of the drive with the line hooked up in this picture.
