Re: What is this?
I do better with pictures, so maybe the link below will help you also:
http://www.*****************/parts/...&manufacturer=Johnson§ion=Intake+Manifold
I do not have a service manual for that model but the parts schematic should help you. As you can see, there are other springs #14 and retainers #46 that will be needed to complete the repair. The missing OEM parts probably went down into the exhaust housing opening below the powerhead. To avoid that same fate with the repair parts, stuff rags/towels into the opening between the bottom of the powerhead and the cowling. FYI, those parts in your hand will cost over $50.00 to replace! Good luck!
EDIT: iboats.com is suppressing the link to a parts diagram on another website and I fully appreciate the reasons why. Will try to find you another picture unless some other forum member beats me to it.
The best I can do for you is this old forum thread with a link to a Clymer non-factory service manual:
http://forums.iboats.com/boat-topic...nline-service-info-not-just-boats-393281.html
LOGIN as directed and drill down to: Small Engines, Marine/Boat Motors, Evinrude/Johnson, Outboard 3-Cylinder Models 65HP, Condensed Service Data. Carb/choke info is on page 3.
