What is this?
89retta
Hi guys need some help. I have an 04 Caravelle 187. It has a 4.3 gxi-e with an sx-m 1.79. Just noticed on the underside of the cavitation plate there is a rectangular opening. What is this for or am I missing a cover off it. Tried to find a pic of an outdrive with same opening but couldn't. Thanks for any help
89retta
I keep the boat at the lake so I will take a pic of it this weekend.
89retta
No Title
Found a pic of what I'm talking about. The opening is just above cavitation plate there is one on both sides. Its the small rectangular opening.
skydiveD30571
If I remember correctly from older threads, that opening is by design and you are not missing anything.
89retta
What does it do? Is it for the exhaust? thanks for the reply
Tail_Gunner
Yes its a exhaust port as is the prop and the transom water outlet.Notice the three outlets or sources on smoke.
89retta
Thanks for the info. Can I block them off to make the boat more quite at cruising speed?
