What is your thought on inner tubes for 5.30x12 trailer tire?
Ryanmolnar55
Found some online for cheap and I figured I'd see what you guys thought of using inner tubes instead of replacing the tire.
foodfisher
Re: What is your thought on inner tubes for 5.30x12 trailer tire?
Clean tire innards and a tube "could" add some usage.
im against inner tubes in general because most tires can be plugged from the inside and any tire that need more than a plug to fix it is past its best. that's just my personal opinion
smokeonthewater
If the tire needs replaced replace it
Ryanmolnar55
Yea Im gonna just replace the tires, 2 of them are dry rotting.Thanks guys
Bamaman1
New 12" tires with new wheels are very inexpensive.
If inner tubes were so good, we'd still be seeing them being used.
I do wish I had about 4 16" inner tubes to float in the river with, however.
slowleak
The problem with having a tube vs a tubeless tire is that when a tube gets punctured it goes flat and requires tire removal to repair no matter what.
Without the tube, the puncture don't always cause a flat, such as a nail in a hole, and a simple plug fixes the problem fast.
I carry a plug kit at all times in all my vehicles, its more than once gotten me home without changing a tire.
With a tube, its flat and you need a tire machine or a lot of sweat to fix it.
I usually limit tubes to farm use and non important things like handtrucks, wagons, and farm vehicles that don't leave the yard.
Ryanmolnar55
Very good point's thanks.
colbyt
Master Chief Petty Officer
While I very much agree with "New 12" tires with new wheels are very inexpensive. ". I can't agree with the why we aren't using them. Mfg. costs and labor costs are far more likely reasons.
The only place I run tubes is the wheel barrow, 2 wheel dolly and the garden tractor. I just plain got tired of having to pump them up every time I wanted to use them.
