Ok guys I need some advice. I'm sure I could call Johnson outboard customer service and get this answer but I have fluid in my current hydraulic motor that may not be the correct kind. So I just bought the boat and the tilt trim isn't working like it should. Its a old 1977 Johnson javelin 85 hp. When I loosen the screw on the hydraulic motor its a reddish color fluid so I was guessing that would be a ATF transmission fluid? Is that correct or is that the color of Johnson's trim tilt fluid? And should I try to pump all of that fluid out and start with a new fluid or pour new fluid on top of current fluid and trim tilt the motor 3 to 5 times hoping thats my problem? I hope what ive wrote makes sense to someone and thanks in advance
