What kind of oil?
loritom
I have a Panther power trim and tilt and I need to know what kind of oil should be used in this unit. This is a screw type unit and has a breather type fitting on the ram and a plastic fill cap on the end of the motor housing.Thanks for your help.<br />Tom
JB
Re: What kind of oil?
Moving to General Outboard
rickdb1boat
I thought that was an electrical T & T unit?
loritom
Yes,This is a electrical unit but it still needs some kind of lubercant :confused:
rickdb1boat
So it is a hydraulic unit? I would think any T & T lube would be fine. Lubrimatic makes T & T fluid, as well as penzoil, which seems to work fine for me. Both can usually be had at Walmart.
