What kind of paint for inside floor of aluminum row boat?
jimwalt
My boat is a 1955 and is almost like new. It at one time was painted on the inside floor (maybe from the factory). I would like to re-do this and wondered what type of paint I should use? I'm not sure, but there might be a super tiny hole near the back because I get about 1/4 cup of water after a couple hour outing. I'm thinking that painting around all the rivets and the floor might remedy this if there actually is a small leak.
robert graham
Actually painting the inside may hide a small leak or loose rivet and make it more difficult to find for repair....Mine is a 1983 aluminum canoe with all rivets and I just leave off the paint....If you must paint then locate and repair your leak first...
roscoe
More important than the paint, is the primer.
Clean and lightly sand the surface.
Then use a self etching primer.
Zinc chromate primer if you can find it.
My local walmart sells it in spray cans, in the auto department.
dwco5051
If your boat has plywood on both sides of the transom and it is through bolted that also can cause leakage as the wood shrinks over the years.
