What kind of prop do I need? here's my rpms..
americands
So I had a 4 blade SS that cost me $500ish which I sold to one of the guys here. I was having RPM problems which I fixed so I never had max rpm on it. Anyhow; I bought a Volvo Penta 3 Blade black aluminum 19pitch. My boat's speed is unknown (speeo broke). But my RPM is going to 4800-5000 at wot, so I've been throttling back. The PDF file here states a 4400-4800rpm for the GS models.
1. Would I get like a 21 pitch 3 blade, or a 17 pitch 3 blade?
2. When I change to the recommended pitch in # 1, will my boat go faster or slower?
thanks
Maclin
Re: What kind of prop do I need? here's my rpms..
If your tach is accurate then the 21 pitch is what you need.
With the 21 pitch the actual boat speed (assuming no prop slip) would be slightly higher at any given RPM when compared to the 19 pitch.
steelespike
It would help to know what size boat and your horsepower or displacement.
If your running a 3.0 a 21 might really sap your power.
With the rpm so close to right I wouldn't make any prop change until you get the speed to go along with the rpm.
A gps for speed works really well.Some cells have a gps app.
Maclin
Hi Steele, the OP had posted in the VP section about his boat recently so I already knew a little bit about his sitch. I will let him post more in regards to this, but he has a V8 in a 20-21 footer.
Maclin
I think he went from a 2bbl to a 4bbl, and is in the process of re-tuning the boat now.
americands
Correct, my boat is a 5.7GS Volvo Penta on a Caravelle Interceptor 212 (21'). It's a 4BL (the intake was a 4bl but someone had a corroded 2BL on there that I replaced). My boats now maxing RPM's and at WOT 5000rpms. So it's got a 19 pitch 3 blade aluminium on it, so I thought I had to go down (like 17), but I guess I'm to go up?
So at WOT on 5k rpm's, if I went to a 21 pitch 3 blade I should expect (1) more speed and (2) a lower rpm? Probably around 46-48?
thanks again guys
Philster
Pretty much. Yes.
You gonna do stainless steel?
steelespike
It helps to be well read. I don't get around enough I guess.
