What kind op prop for my boat ??
stingraymax
Hello I just bought a 1999 johnson 90Hp outboard engine to put on my 17ft Rib there is a 13 3/4 x 15" aluminum prop on it now but I would like to install a stainless steel prop but what kind would be the best for me ? (Viper, renegade,SSt,raker )<br />The boat weighs about 450lbs without engine and it would be used to waterski from time to time on the ocean and otherwise just cruising.<br /><br />Thanks
Solittle
Re: What kind op prop for my boat ??
First you need to mount the motor with the cavitation plate even with the bottom of the hull or slightly above (say up to 1"). Take it for a run and let us know what rpms you are getting at wide open throttle. The recommendations for a prop will be based on that.
