What mercruiser outdrive do I have?
the uninitiated
So I bought a boat to fix up. I need to change the seals in the outdrive but have questions as to which one I have. I know the boat (1987 Sea Ray Sundancer 250) originally came with 454 Magnum and Alpha One outdrive but I have found in a previous owner's documentation the installation instructions for a Bravo One. I checked for a serial number to match but it was un-readable. I have attached some pics if anyone can point out the physical attributes that make it Alpha or Bravo. Thanks in advance for any help.IMG_4356.jpgIMG_4357.jpgIMG_4358.jpgIMG_4359.jpg
JASinIL2006
Re: What mercruiser outdrive do I have?
So I bought a boat to fix up. I need to change the seals in the outdrive but have questions as to which one I have. I know the boat (1987 Sea Ray Sundancer 250) originally came with 454 Magnum and Alpha One outdrive but I have found in a previous owner's documentation the installation instructions for a Bravo One. I checked for a serial number to match but it was un-readable. I have attached some pics if anyone can point out the physical attributes that make it Alpha or Bravo. Thanks in advance for any help.View attachment 202313View attachment 202314View attachment 202315View attachment 202316
Ayuh,.... The PO was just Dreamin' 'bout a Bravo,...
You've still got the Alpha 1,...
