What Mercruiser outdrive?
AdamB
Hi, I have a 1984 Wellcraft Elite 210, with rebuilt Chevy 350, and the original outdrive was replaced in 1993.<br /><br />The paperwork I received with the boat says rebuilt alpha, but can anybody confirm what outdrive by the following serial #: OB565444?<br /><br />Thanks in advance. Oh, the outdrive has been repainted and there are no stickers displayed anywhere. I need to order new gimble bearing and such...
Don S
Re: What Mercruiser outdrive?
That serial number is for a 1987 Mercruiser MC1 drive with a 1.50:1 gear ratio.
AdamB
Thanks Don, appreciate the quick answer. Do you mean this is an alpha 1, or is it pre-alpha?
Alpha 1........<br />It'll have a "Flat" top cover.........<br />Pre-alpha, Mod.1s have the lifting "Eye" on the top cover........
waterone1@aol.com
That is a standard rotation Alpha 1. The Drive you have is a 1.5:1 gear ratio.
AdamB
Okay thanks guys, I thought it was an Alpha, but the skeg protector (or whatever it is called) on the bottom doesn't match those I've seen in pictures. Maybe it was modified.<br /><br />This forum is great. Thanks again to all!!
Don S
It's NOT an Alpha I, it's called the Mercruiser One drive, it was prior to the R, and MR, but looks similar to the R & MR with the lifting eye on the top cover. And it probably looks similar to the drive below.<br /><br /><br />
AdamB
Okay, now I'm confused. It does look like the above photo, with the exception that it doesn't have the lifting hook on the top cover. <br /><br />Don S, so you are saying this is a very old drive that the previous boat owner boat rebuilt in 1993?, and not a rebuilt alpha like on the sheet from the marina?<br /><br />The previous owner paid $2500 installed for this outdrive in '93.
waterone1@aol.com
Serial number 0B565444 IS a part number 01501017<br />Which tells me it is a MR or Alpha drive. Not an "R" or anything before.
Don S
If you have the flat cap, it's an Alpha.
AdamB
Thanks for all your help...<br /><br />Okay, my top is flat, and the area around the vent isn't ribbed, so I guess this is an alpha. My skeg protector (if that's what it is called) looks like the gen I, I saw a gen II and knew mine didn't look like that.<br /><br />This pic below, is my outdrive supposed to have the trim tab below the cavitation plate, or is that an option?? Mine only has a round plate above the prop.<br /><br />
tommays
adam<br />the plate is a zink it comes round or with the tab to help the steering<br /><br /><br />tommays
AdamB
Okay, thanks everyone.
