What Mercury Power Head do I have?
skutsch
Ok so I picked up a bit of a rare bass boat, and it has a 135 Mercury Black Max on it but when I picked it up the seller said, "I think somebody swapped the powerhead cause its pretty fast" So here are the numbers I got off the motor and I am trying to figure out what I have.
Serial Number on the ID Plate (near the transom mounting brackets): 0A957475
Number on the Frost plug on the port side cylinder bank: 5904475
Number stamped on Starboard Heads: 1026-7261
Front of block below the flywheel: 95785
Port Side behind timing advance arm: 030281 (I assume this is the "born on" date)
Relief Valve Plate: 65663
On the block between power packs and heads: 7914 or 7974
Thanks in advance for any help you might provide!
Fun Times
Ok, so teach me to fish... what numbers lead you in that direction?
Using the serial number on the frost plug shows it to be a MERCURY - (150 H.P. (1980) Serial No: 05904475 Model No: 1150620 Parts Catalog No: 90-818855
2.0L 150 ELPT
PARTS CATALOGS
  • 818855 - 150 H.P. XR-2 MARATHON MAGNUM (V-6)
Your number on the transom comes up as an MERCURY - (135 H.P. (1986) Serial No: 0A957475 Model No: 1135726 Parts Catalog No: 90-13752
MERCURY 2.0L 135 ELPTO
PARTS CATALOGS
  • 13752 - 135/150 H.P (V-6)
