I can't find any ID plates on my motor, but this is cast into the block: 5 121385 (top left). This is cast into the transom mount (left side): 1440 7373.
I believe it's an 85-87' 50hsp Mercury, but everything I look up comes up short. It's a 3cylinder with two square bowl carburators with enrichment valves on the left. It has a high pressure water pump, and a preload drive shaft. The cowl is fiberglass with grey stripes... if any of that helps.
Ordering parts is a PIA without knowing just what I have. It could be possible it's a 60hsp (who knows if the cowl was swapped!
Thanks,
Jeff
Thanks,
Jeff
