What mounting holes do I use?
Dennischaves
Im getting ready to hang a 84' 70hp evinrude on my glastron
what mounting holes should I use
the boat came with no motor so I have nothing to go by
flyingscott
With the motor level make the cavitaion plate even with the bottom of the boat.
Dennischaves
Thank you
one other question for future reference
where should I start as far as where to put the long tilt stop bar that adjusts how far down the motor will tilt down
flyingscott
If you have power T/N/T all the way to the bottom. If you have manual tilt start in the second hole out. That will get you started and you can fine tune from there to find a balance between holeshot and wide open speed.
