Re: What octane does a OMC 3.0L GM engine take?
The manufacturers of marine drives, whether I/O or OB's, sell their products WORLDWIDE.
Knowing that fuel quality may not be the best worldwide the manufacturers design their engines fuel requirements to the lowest grade fuel available.
87 octane should be fine for most all marine engines.
As Jason said, if you experience any problem with your particular engine, check the timing carefully. Many service manuals allow up to 4 degrees retarded timing to compensate for any spark knock or pinging caused by low grade fuels.
