What oil to run?
tgissel
What type of oil should I run in an older cabin cruiser no idea of hours single engine 318 w/ velvet drive transmission.<br /><br />Thanks :confused:
crazy charlie
Re: What oil to run?
Sounds like SAE 40 to me .The manual probably calls for sae30.I would stay away from the synthetics for an older motor because you probably have a small oil leak somewhere and the use of synthetic WILL make it worse.Charlie
Scaaty
40w fine, 30w if ya can't find it. Just stick to straight weights.
