Re: What oil to use to replace in upper/lower unit
Look on the front side of the drive ( just behind the transom) about 1/2 way down there is a small hole in the middle. Back in there is the swivel bearing grease zerk. A small flex hose and a small grease coupling head will go in and
find the zerk.
Give it about 10 shots of triple guard grease.If the swivel seals are going bad this will seal them.
You will know if you have a problem with them, your temp will suddenly go up.
This is caused by the exhaust gases being sucked past the seals and going in the cooling water.
I know sounds nuts but it happened to me. All at once the temp started climbing, took boat home changed both water pumps, no help.
A OMC mechanic told me about the seals going bad, said give them about 12
shots of grease to seal them. IT WORKED!
Replaced lower next year with a full mechanical shift, New seals , No problems
Beef
