what paint to use on fiber boat???
sylvain36
i want to know what paint use on my 18' fiber boat i want to do with roller foan and someone say i can do great jog like paint gun?what do you think?
thehermit
Re: what paint to use on fiber boat???
syvain, just finished my paint work. used interlux brightsides over interlux prekote primer on hull and topsides and interlux interdeck over epoxy barrierkote on deck - all got at least 3 coats with mohair roller and tip. I dont wat to sound like an Interlux salesman but was basically looking for a one part poly paint I think there are may brands that will probobly get you similar results. all these posters had some good input:<br /> http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=26;t=002025#000002 <br />Very happy with the results (application easy finish looks great)-well see how long they last.
petrolhead
Use a primer that's intended for polyester, then topcoat with Brightsides, Toplac, or a similar product. Most say not to use below the waterline, but if your boat is trailered and doesn't spend more than a few days in the water at a time it'll be fine, most manufacturers will tell you this "off the record"!<br />For best results apply with a foam gloss roller, the thinnest foam (short nap) cover that you can find, and "tip off" with a soft brush afterwards to get rid of any air bubbles that the roller forces into the paint.<br />Tipping off is best done by a second person following the roller as it needs to be done quite quickly. It involves dragging the brush very gently, just barely touching, across the fresh paint surface. Enough so that it bursts any bubbles but doesn't leave brush marks. 3 coats of gloss should be enough to give a really nice finish, almost spray quality.<br />For a more durable finish use a 2 pack gloss, using the same application method.
sylvain36
if i use 2 parts polyurethane like MICCA paint i ave here ist 100$ per gallons dos i ave the same result and the guy i talk for polyurethane sayd its not good for the bottom of my boat i said the paint dont stay on the boat because pressure on the water when the boat run this is right?? and when i finish painted whit polyurethane can i sand with 2000 grit and counpound 3M is ok??
