What part would someone call a "head" on an outrive?
couger300
Title says it all. Going to look at a boat and the guy says it leaks a little gear oil after the marina put a new "head" on the outdrive? I've always had outboards and have no idea what this means or how bad or costly it will be to fix? Thanks in advance!
GA_Boater
Re: What part would someone call a "head" on an outrive?
Don't feel bad. I'm unsure as well. Won't even speculate. Please tell us dummies when you find out! :smile:
couger300
Ha ha! Regardless of what it is am I correct to assume if oil can get out, water can get in?
GA_Boater
It depends on what "head" the seller means. If he means lower unit or the upper, water could get in.
K-2
I don't have a cue what he is taking about,,,but neither does he:laugh:
couger300
"No water can not get in . The head is on top of the out drive which turns the drive that's all". Does that help?!
Im going to take a wild-arse guess and since the lower is sometimes referred to as the foot, maybe he is talking the upper gear box.
which drive? I ask because if its a 290, the upper gear case is apparently made of gold or palladium based on the prices.
GA_Boater
You made that up. :lol:
