What Pitch is My Prop
Ltdoug
I have an aluminum prop on a 96 Bayliner 2452 Express. It has # 36-16436-14 in raised letters on the rear of the hub. The first two letters were obscured and may not be correct. It measures 14 inches in diameter. I need to know the pitch on the prop. Can't find any info in Michigan Wheel or other manufacturers.
JB
Re: What Pitch is My Prop
Measure the distance along the centerline of the prop from leading to trailing edge of one blade. Multiply by 3.<br /><br />Good luck. :)
