What pitch is this prop?
b.gagnon
Master Chief Petty Officer
It is a mitch Stainless 973001.<br />I just got it from ebay. It says(in marker)17p.<br />I hope it is right, but if not I just bought a Stainless spare for $54!!!
stevens
Re: What pitch is this prop?
I don't think that number means anything, at least I can't find it in the Michigan Wheel catalogue.<br /><br />In any case, you found a new steel prop to fit your 1979 Chrysler outboard, and for only $54 - Congratulations!<br /><br />No reason yet to doubt the seller's word that it is a 13x17 prop. Please let us know how it runs. It looks good in that picture on ebay:<br /><br />
<br /><br /><br />Oh, by the way, here's a neat page for finding exact replacement props based on the OEM prop number:<br /><br /> http://www.propmd.com/c-593-oem-boat-prop-exact-replacement-list.aspx
b.gagnon
Yea this prop is brand new! It is not that I don't trust the seller, it is more the fact that they had no history in marine parts. They more than likely bought a bulk of props somewhere that were already labeled. I will give it a try this weekend. Worst case, I keep it on hand as a spare.<br />One concern that I do have is the weight of this thing. It weighs close to 10 lbs! Could this be a problem with a 1979 Chrysler 70hp?
stevens
Yes, steel props in general do feel heavy when compared with alu props. I don't think it's a problem as long as you shift it gently into gear. Once it's spinning, I would think the added weight only means extra inertia to keep it spinning smoothly. Walleyehed, any views on this, please?<br /><br />It'll be fun to hear how the rpm, speed & slip compares with your old prop.
walleyehed
The biggest load on the prop is when shifting and load the blades with water-flow, it's not so much the weight as one might think. If we were in nothing but air, the inertia factor would be very great, but in a fluid, it's quite a bit less of a factor. <br />And, when you shift, snap it into gear briskly, don't do it slowly, that just lets the gears grind for more wear before thumping into gear.
stevens
"Snap it into gear briskly", but I guess don't slam it straight into reverse from going forward, or vice versa. Take a pause in neutral in between.<br /><br />Or, as it says in my Mercruiser manual:<br /><br />
Control Handle - Operation of the shift and throttle are controlled by the movement of the<br />control handle. Push the control handle forward from NEUTRAL with a quick firm motion to<br />the first detent for FORWARD gear. Continue pushing forward to increase speed. Pull the<br />control handle back from NEUTRAL with a quick firm motion to the first detent for REVERSE<br />gear and continue pushing back to increase speed.
