What pitch propeller?
I have a 1975 Century Raven 225 with a 188hp Mercruiser 302 sterndrive. The propeller needs replacing but I cannot determine the pitch size. Does anyone know the manufacturers recommended pitch size or a good all around prop size recommendation for this boat?
steelespike
Re: What pitch propeller?
Unfortunately unless someone has that same rig prop selection is pretty tough.
Size or part number is usually on the barrel or under the prop nut.
If no numbers a prop shop can measure it for you.
If you read the stickies at the top of the page and the helps on the iboats prop store page it will be easier to understand prop selection.
If you can get us the prop size and your max rpm and speed with that prop
we can help with a prop selection.Also wouldn't hurt to tell us what
type boat the 225 is.Weight?
