What prop for 19' cuddy?
chris0061
Hello all, I've gotten a 1986 Regal Sebring cuddy cabin, 19' long and weighs about 3000 pounds loaded with the Mercruiser 170 and alpha one out-drive. I'm currently getting 4300 rpm at 40 mph. I've got the clymers coming for rmp range and gear ratio to do a analysis but my question is were do I want to start testing props. I'm looking for the most mph at the best rpm range as we do not pull skiers or tubs just fish and cruise. I believe my current prop is a 19 pitch and its alum. I will go with a stainless. Any suggestions on what kind of prop, 3 blade, 4 blade exc. Thanks in advance, Chris
steelespike
Re: What prop for 19' cuddy?
Your presnt performance seems pretty good.I'm guessing your max rpm is 4,600 and you are certainly within operating range.
I would try to find a dealer that will exchange props.There is an exchange program here at iboats.I would start with a 3 blade stainless in the same pitch.My limited experience has been that when going from AL to SS it can be a little un predictable some SS lowering rpm but raising speed and others raising rpm and speed.Perhaps the experts will chime in with some specific suggestions.
tarheelebbtide
The above advice is good. In my experience, you'll most likely see a slight decrease in RPM with the same pitch stainless as it doesn't flex as much as the aluminum and is a heavier wheel to spin.
Turbo1
The weight of the prop has little to do, if anything with how the engine will turn it.
90% of the increase in weight is close to center in the inner/outer hub.
Alum does flex more giving better hole-shot, but SS's lack of flex is not the reason for speed gain....blade geometery and extra lift from such is the reason.
18P would be good in a 4bld, I "think".....and give better hole-shot but some loss of top-speed will occure over the 3-bld.
