What Prop for 1982 Monark McFast w/ 3.8L OMC Sterdrive
DuWayne.Melton
Can anyone tell me what prop I should buy for my 1982 Monark McFast fish/ski? It has an OMC 3.8L inboard engine with a OMC outdrive modle number 983159. The prop on it (that I just bent) is a 14.5X19. I am happy with the performance of the original prop so really no need to change anything as far as pitch. I just don’t know what outdrive (800 series ?/right or left hand) to tell the prop people to order the correct one.
Get another 389924 prop or take your prop to a prop shop and have it repaired
DuWayne.Melton
I’ve tried ordering a 389924 prop on several sites but I keep getting zero results. I’ve googled it and can tell it is an OMC prop part number but the number must be outdated. So I was looking to see if anyone knew the updated part number/prop.
your not going to find new, only used on Ebay. props for the stringer drives from OMC went away when OMC went out of business.
Faztbullet
That part number change to a 0763918 which is now called a Viper prop...
Part Details
Part Number0389924
OMC[SUP]®[/SUP] SYSTEMATCHED[SUP]tm[/SUP] Part#765812
Supersession->0176617->0763918
DescriptionVIPERTBX14.75X19RH
Pack Quantity1
Weight/Dimension17.00 lbs / 17.50 in length X 16.00 in width X 8.00 in height
7.71 kg / 44.45 cm length X 40.64 cm width X 20.32 cm height
Viper TBX™ (14 3/4 x 19") EVINRUDE® JOHNSON® RH Propeller, 763918
Item: 0763918
Size: 14 3/4 x 19"
