What prop next?
Poppajoe
Can someone help please?<br /><br />New here, so hope I have done right?<br /><br />I have used various prop calculators and I am getting more confused.<br /><br />I have an 18ft Icelander fishing boat with a ford xld 1.8ltr, 60hp diesel through a Volvo 280 single prop drive.<br /><br />Details below, but I need to know what sort of revs I need to be running at.<br />The prop calc suggests 14x12 or 15x15 depending what hull shape, tried both and with 15x15 she bogs down at 2300rpm at about 11 knots, with the 14x12 she runs at 2800rpm at about 14 knots.<br /><br />The calc suggested 17 and 23 knots respectivley, in fact with the details entered at their worst case senario I could not get a figure below 17 knots suggested.<br /><br />I would presume that smaller dia and larger pitch (ie 12x17) would reduce revs?<br /><br />I am not looking for any particular speed but want to obviuosly run at the highest possible. I am not concerned with fuel consumtion and do not mind wearing out an engine at around 500/1000 hrs.<br /><br />I can post a pic of boat showing hull if it helps?<br /><br />waterline length = 16ft<br />max revs = 4800 (60hp)<br />max torque = 108 NM @ 2500RPM<br />drive ratio = 1.89:1<br />boat weight = 1300kgs (max checked on weighbridge)<br />max prop dia = 15"<br />Hull form? = on plane would be very shallow "v" about 10 degrees?<br /><br />Any help would be much appreciated.
Don S
Re: What prop next?
You have lots of info there Poppajoe, but you should really post it over in the Props forum.<br />Here is a link to that section.<br /><br /> Prop Questions and Topics
Purduebarry
Re: What prop next?
Hey Joe,<br /><br />Welcome to iBoats, I'm sure the moderators will accomodate you in a moment when they move your thread to the prop forum. Scroll down and you'll see it. You'll get better answers there too.<br /><br />The only thing I can say is wow, I'm always worried about fuel and I sure don't want to burn up my engine, you Guys in the UK are crazy.<br /><br />Do you know the WOT rating for your configuration? You need to know this first. Then you can get some answers!
Poppajoe
Re: What prop next?
Thanks guys - I just realised the prop section may be better, sorry.<br /><br />I only use it for pleasure fishing for about 25 days a year at about 3 hrs steaming so not too worried as the engine is a marinized (correctly I might add) automotive which are readily available here.<br /><br />The post has got the WOT in it is rated 60HP at 4800 - is that what you mean?<br /><br />I will leave it for a while and see if the mods re-post then - cheers guys
