Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
Unless someone has that combination we aren't likely to have that info
And the actual selection would depend on your typical load and activities.
If you run it and get us the prop size, max rpm and speed and your activities
we can suggest a prop.We also need the max recommended rpm usually on a label on the motor.
