arrivawaker
- Jul 24, 2012
- 4
Hi I just bought a boat for cheap and it had a 5.0 in it but the owner was dumb and failed to winterize it this last winter and put a hole the size of my fist in the side of the block and cracked the exhaust manifolds. I curently have the manifolds at a local metals shop to be welded and I am building a 5.7 to replace the 5.0. I have never owned a boat but my dad has so I am not new new to boats. But I dont know much about what prop to use and I have heard that elevation can effect the prop that you use so here is my question. I am mainly going to be using the boat at lake powell and a lake near me called highline. Highline lake is at an elevation of 4600 ft. I am wondering what prop would be the best for a quick launch and not rob to much of my top end speed? I will tell you a little more about the boat in case it will help.
1989 Bayliner Arriva 20 ft that will have a 5.7 with an alpha one. The 5.7 will have a little more hp than a stock 5.7 but not too much. The boat weighs about 2500 lbs and is a 20ft. If there is any other info I need to give you let me know. Thank you!
