what prop size and pitch
capthook
I have a pre alpha matched to a 4 cylinder mecruiser 3.0L running on a 1973 18 ft Reinell closed bow. I was just wondering what would be the best prop for pulling tubes knee boards and skis. I mainly run on the IL river so I am going to be sticking with the aluminum prop. Any advise would be great.
Re: what prop size and pitch
Without knowing What Prop you've tried,+ the Results of running that Prop,..........<br /><br />Your Question is Unanswerable.......<br /><br />But,....... I'll give you a "Guess"........<br /><br />Try a 19"..........Then check the rpms,+ decide if it's Too Big,... or to Small.......
JB
Prop topic.
SteveNix
What are size/pitch are you running now? and what kind of wot rpm's are you @?
gatorred
what's on your boat size/pitch mumbers like 14in / 19p to low rpm on tack go down in pitch try 2 like 19 to 17 bring rpm's up if to high go up in pitch but you need starting point you need to know what you have then go from there
minion
I run an 18 foot bow rider with a 3 liter as well.<br />I run a Turning Point "Hustler" prop. (ALUM).<br />14.25 X 21 pitch .4700 RPM @ WOT...perfect!<br />We pull tubes and cruise mostly.<br />I cannot get this prop to cavitate/disappoint me.<br />Hole shot is great , pulls tubes with ease.<br />I too run the Illinois(Morris) as well.
