what prop to use?
fordmugg
hello im new to the forum and i have a question i have a 1974 17ft kona boat with a 115 mercury outboard it has what i think is a 19 pitch 4 blade. my question is i would like to get a little more top end ...the boat gets out of the hole real fast but only goes like 35 maybe 40 if trimed right.....so could i go to a 21 pitch and a 3 blade or stay with a 4 blade ? sorry im new to boats and any info will help...just want to go a little faster ............thanks
Re: what prop to use?
Ayuh,......
Just like Everybody else,.....
You've Got to know the rpms at WOT,+ your Speed,.....
Without that Info,..... You'll only get Guesses.......
steelespike
Like bondo said we need actual prop size,max rpm and speed. (gps is best).
Don't make any prop change without this info.
Generally a 3 blade will produce more speed than a 4 blade.
You also should optimize your setup.Raise the motor verticle height to a point just before venting becomes a problem.An inch could get you 2 -3 mph depending on where your at now.This could also improve your economy.
If your getting 40 with careful trimming your pretty near the max depending on boat weight/style etc.
fordmugg
sorry like i said im new to all this so ill find out what rpm and speed it runs at WOT and then ill re post....i mean the thing needs a new prop anyways because its getting pitted on the blades like its eating a hole through it
Ayuh,......
That sounds like cavitation Burns,.....
SS is probably Right,... With a New prop,+ some refining of your Set-Up,.....
You'll think you've got a Brand New Boat.....
Btw,......
Welcome Aboard to the forums here at iboats.com................:)
fordmugg
thanks as soon as i get the rpm and speed ill post back
