Hi Everyone,
I am trying to figure out what would be the best propeller for my boat. My goals in choosing a propeller are getting the best fuel economy and a high cruise speed (speed where the boat has the best fuel consumption) while not putting to much stress on the engine (RPM not too high). My boat is a 1999 Boston Whaler Ventura 180 and the engine is a 1999 Johnson Oceanpro 115, 2 stroke outboard. The model number of the outboard is J115PXEEM. From research I have done using a model number decoder I have found that this engine is the X-Long length of 25". I believe the boat goes 32 or so MPH at WOT (5200 RPM) with two people and 35 gallons of gas. Those are the numbers I remember from last year but they are likely slightly off. The boat has no problem getting on plane relatively quickly. I usually run the boat with about 3 or so people on it weighing around 150 pounds each, 20 pounds of gear, and 45 gallons in the 60 gallon tank. This is an approximately 750 pounds over the dry weight. I sometimes run the boat with 6 or 7 people and close to 50 pounds of gear with a full 60 gallon. The current propellar is the aluminum one that came with the boat when I purchased it used. It is chipped and the only numbers I could find on it without taking it off are 06B&S863 and 04B&S968. Any help in choosing the right propeller is greatly appreciated.
Thanks,
Hikehike1
Thanks,
Hikehike1
