boatingdudebmk
- Mar 27, 2013
- 24
Hey iBoats
I am new here, and I need some advice on what RPM my boat should be running at. I know there is a specific range of RPM that any engine should be running under load. I have a Evinrude 25 hp ELCOC (pretty sure thats right) Its a 1985 and it will be mounted on an Addictor Mini Boat, 8-9' Long, 4'4" Beam. Boat weighs 300 dry, so with 6 gallons fuel, small lawn tractor battery for electric start, and the engine (100-125 lbs roughly) and two passengers, it should run about 775 lbs. I haven't run the engine on the boat yet (engine currently on boat went under) and have to get a tach reading. What prop should I be looking for? (pitch and diameter, and a recommendation of material [stainless, aluminum]) I will be running in muddy bottomed water, and when I get a trailer, in lakes around my area. Thanks so much!
