Re: what size air compressor for boat restoration
If you are looking to run air sanders , they take some air .
A little 110V / 5 gallon tank compressor is just going to be a PIA .
You are going to need a 220V , 4-5 HP rig with at least a 40-50 gallon tank .
You need something that can sustain 10CFM @ 90 PSI .
Any less than this and you are wasting your time .
Be leary of the ratings on "consumer end" compressors , they are generally very optimistic , to put it politely .
Expect to spend ~$500 for a decent unit , more if you need to have a 220 circuit run for it( I ran my own ...) .
Don't forget all the extras like a moisture and oil seperator , regulator , lines , couplers , valves , hoses , etc..
These add up in a hurry , if you are plumbing the shop for air .
