What size battery?
gamekeepa
What size battery do i need for a suzuki dt30?Does it have to be a special type or will a car battery be ok?
James R
Re: What size battery?
A car battery is not designed for marine use. A marine battery plates are supported to prevent internal collapse experienced when boats bang about on rough water. A small marine battery will suffice.
Pas Bon
A car battery will be fine to start that little motor. The amount of bouncing around in the back of a boat is not that much different from under the hood of a car.
However one labeled "marine" might already have the wing nut terminals on it.
A marine battery is typically a deep cycle, which you don't need unless you will be running a trolling motor.... you need a starting battery. Both will work but you will probably pay more for a deep cycle or a battery labled "marine".
