What Size (I.D.) Hose Do I Need?
JoLin
I may have a high-speed overheat issue on my port-side 4.3. Haven't confirmed it yet but I want to get some things ready for when my friend and I water test it to confirm. I have an IR gun, and I want to replace the t-stat housing to starboard manifold cooling hose with a clear hose to check for air at 3,000 rpm, per Merc's troubleshooting bulletin.
I'm not at the boat, and just wondering if anyone knew offhand what size (I.D.) hose I need for the connection. I can pick it up before I go back to the boat. Thanks.
Bt Doctur
But in most cases the water pump base is sucking in exaust gas
