Re: What size kicker?
As far as I know, the only geared-down kicker is the Yamaha 9.9 high-thrust 4S (if I'm wrong, someone will correct me!). I use one on my 24' Seaswirl, and I don't have to run it more than 3/4 throttle to get to hull speed (about 7.5 mph). I see other brands have sailboat and/or pontoon models, and those make the best kickers.<br /><br />Hull speed on your boat is about 7.4 mph (sq. root of 22.6 X 1.3 [= knots] X 1.2 = mph). No matter how much hp you put on your kicker, it won't go faster than that, so don't waste extra money buying more horsepower than you need.<br /><br />Don't know what kind of fishing you do, but I think the kicker is worth the money. Not only does it provide get-home capability (although, knock on wood, I've never needed it), but my main motor won't go down to the low speeds we need for salmon and steelhead. Plus...I can troll for hours on a gallon or two....try that with your 200.<br />For true get-home capability, the trolling motor should run off its own tank. Mine's hooked up to my main tank, so if I had contaminated fuel, I guess I'd be in trouble.
