What size motor for my boat?
I have a 16' aluminum boat (Grumman) we have striped it down trying to eliminate as much weight as possible.It currently has a 50hp mercury side console steering motor I want a tiller motor. Can I go with a 20 to 30hp motor?
boobie
Re: What size motor for my boat?
What's the boat rated for in horse power ??
coolbri70
^ also, how fast are you needing to go?
boobie
How's it run with the 50 HP Merc that is now on it ?? Normally when you go tiller you have to drop the horse power. Safety reasons.
steelespike
What year boat? Do you have a model number?Does it have a live well,floor,built in tank
If you count jon boats there are probably 15 16 ft models.
the boat is a 1989 gruman 16' ss . i have removed the live well ,steering console and storage boxes. I pulled the wooden floor out and replaced it with aluminum diamond plating all to reduce the weight and open up the floor.
Chris1956
Well, there are some commercial tiller steering motors with up to 85HP, so you will have a choice. Why did you strip her down? Was it simply to use a smaller motor?
younggun
Guessing that he's a duck hunter it was probably to open it up for duck hunting. I did the same thing to one of my boats
steelespike
What will be your typical load?If the 50 merc is sound there is or were tiller kits for it.
I have a 1965 50 hp tiller motor and I had a 77 tiller motor.That I added the tiller to.
As far as big tiller motors I've seen 115s with tillers.
not so much the motor size but to clear out the clutter. We hunted out of it this year and all that stuff was in the way making it unsafe in the bay.
Yes it's for hunting. I looked up the serial number and it looks like the motor is a 1989 a local boat shop said there is not a tiller kit available is that true? I would prefer to keep my motor and install a kit if I could find one.
oldboat1
Shilshoe Bay or Chesapeake Bay. Which Washington? And how fast are the ducks you are chasing?
sorry. Would think a tiller 30 or 40 would do the job with a hunting partner and decoys up in the front of the boat. Boat should be pretty quick, and probably w/i hp limits for that hull (which would be good to determine). 2-cycle would be lighter than comparable 4-cycle, if that is a factor (but louder. must be vewy vewy quiet when duck hunting... sorry) :)
ondarvr
You can buy a tiller for yours, but it can be costly, check eBay frequently and you should be able to find one at a fair price.
Washington state. It's not about speed or noise am just having a hard time finding a tiller motor at a reasonable price over 40 hp
oldboat1
well, still thinking a 25 or 30 (40?). Can you come up with a tiller model in that hp range? It's a pretty light boat. "Older" for me is '50s or '60s, but seems like you might be able to find a deal or two on something from the '80s or '90s. Depends on what you want to spend, and how much tinkering you are comfortable with. JMHO.
ondarvr
Just because one isn't listed doesn't mean they aren't available, you can get a tiller for just about any Merc made.
I've had the same issue when looking for one on a different brand, nothing listed for that model, then found out the same tiller will fit almost any motor of that brand built over about a 15 year span.
oldboat1
sounds like you might have a possible source. local source maybe. man needs a tiller.
