Re: What size outboard?
If it is a displacement hull, you won't need much power. Do you know how much it weighs, and how much load you will carry. I am betting that you won't need more than 20 hp. Get a motor with a heavy duty lower unit that has greater gear reduction than standard and larger prop like a Mercury Bigfoot, and you should be okay.
