What size prop do I need?
I have a 1987 17' Fabuglas fish/ski with a 1980 Mercury 1500 on it. I usually just ride and pull tubes/wakeboards. Just bought the motor, and it has a 15p prop, I believe is obviously not suited for my boat/usage. Any suggestions?
Dakota47
Re: What size prop do I need?
17p would work better:cool: but check with the merc guys.
jerryjerry05
You need to test your boat and see what RPM are at WOT. Your motor should run 5500-6000rpm at wot.
Your boat at 17ft and 150hp should probably have a 19 or 21p
The 15 is great for hole shots but in the long run will damage your motor.
Do the test and come back with the results.Jerry
Thanks for the advice, guys. I am in the process of hooking up my tach. I recently swapped motors and the tach never worked, but I'm hoping that I can get it working.
