What size/weight outboard can my boat handle?
Hello,
I am in the market for a new small outboard, 5-7 horsepower. I have a 1978 12' aluminum Starcraft v-hull, and want a reliable motor. Is there an equation to determine the maximum motor weight for a boat?
Courtney
Sea Rider
There should be a tech plate around transom which indicates max carrying capacity along Max HP outboard. 12 footers are for 10-15 HP OB's. 2 strokes less weight are preffered as opposed to heavier 4 strokes with same HP.
Happy Boating
jbcurt00
From elsewhere, where you asked about a best brand to shop for:
82rude said:
Honda,Yamaha,Evinrude,Mercury,Nissan,Tohotsu ,Suzuki are all brands that are trusted and proven.
jbcurt00 said:
I'll add, that in addition to selecting a motor from one of the well established brands 82Rude mentions, I'd pick a motor that has a servicing dealer convenient to you. IMO, nearby service should outweigh a brand preference.
iam2sam
If you do rely on the capacity plate, keep in mind the typical weight of a motor of the specified maximum HP for the era when the boat was manufactured. For example, I suspect that a 1970's boat that specifies a max 45 HP engine (as does my 1972 16' Sea Nymph Coho) could be significantly overloaded and/or unbalanced with a heavy, modern, 45 HP 4-stroke engine with electric start, tilt & trim, etc.
