what spark plug should i use
jdcook
I have a 4.3l v6 that I have been running, and I have been using ACMR43T plugs in it. However this year we added new cam, rocker arms, intake manifold and a 4 bbl carb. My question is should I run a hotter plug than the 43T, I was thinking 44T or even a 45T. <br />any suggestions
Re: what spark plug should i use
Nope.............<br />Stick with the 43s,+ Tune the Carb to them..........<br /><br />No Reason What so Ever to go Hotter.........
Trent
Im with Bondo...No reason to go hotter.
Cobra SX
If you go hotter your will just burn stuff up.<br />BUT are you running a igntion and/or Coil? It would very much help extra fuel from the new carb burn good, you could run your gap a little bigger on that same plug.... it would help all that stuff
anesthes
If the camshaft has different specs, it will change the valve timing and final compression of the cyls. You can't tune a carb to compensate for that, if its too far one way or the other. <br /><br />Assuming you used the same spec camshaft, you should prolly use the same plugs.<br /><br />-- Joe
