What Spark Plugs??
KaGee
2001 Ford Escape 3.0L V-6. 76,000+ miles.<br /><br />Thinking about the BOSCH Double Platinum.<br />Opinions???
Marc J.
Re: What Spark Plugs??
You know what they say about opinions KaGee.... Mine, use what Ford originally equipped it with and change them every 30K. If you decide on a extended life (platinum) plug, use antiseize.
Scaaty
Even the guys at Autozone are voicing opinions against Bosch. I have tried them, and not anymore. AC Delco now with zero probs
Boomyal
Stick with what Ford put in them KaGee. Newer cars get fabulous mileage out of the plugs. I've never done near as well try to substitute the OEM plugs. Are you even sure you need to change them yet. Some of these new cars will easily do 100K on the plugs. My E150 4.6l V8 went 102K before one started missing under load in forth gear.
one more cast
Back in the old days it was Champion for Ford and AC for GM. I would just put in a new set of what I took out.
dolluper
Man the choices are out there,just a caution to you if you do install the platinum plugs whatever brand,wear some disposible gloves!!!!!!<br />Champion-dbl plat #7401 $5 and change per<br />........Iridium #9204 $7 and change per<br />.......Gold #2401 $2.43 per Regular plug******<br />NGK<br />...G plat # tr556p<br />...Laser #ptr5f-11<br />...Iridium #tr551x<br />By the way AC and CHAMP are same company
jimr
Run what it came with and you won't have any problems. I have never had any luck with Bosch plugs in a domestic vehicle. We run motorcraft in all the fords at work and if for some reason someone puts in autolight they don't seem to last as long. We check and or change plugs in Crown Vic police cars anywhere from 26-35000 miles,due to the fact they idle so much.<br />If you have Coil on plug ignition system make sure to change the boots.
KaGee
Well, boot or coil is my problem... got a miss when it's wet. Miss goes away once warmed up. Since I have to take off the upper intake to get at these suckers, I just thought I'd change plugs too.<br /><br />Sticking with the Motorcraft I guess. Geez it chaps my butt to have to buy anything from FORD parts. Almost as bad as buying Marine parts! :D
jimr
you can get motorcraft parts at some napa or most all oreilly's auto parts
craze1cars
Ditto...buy Motorcraft. Not sure where you're at, but you certainly don't have to go to a Ford dealer to buy Motorcraft parts. They're much cheaper and easily available at many auto parts stores. Call around and you'll find 'em.
KaGee
We'll I did it.... bit the bullet and got Motorcraft... @ $5.95 ea.!! :eek: <br /><br />Now to find the boots... NAPA said they are available via Special order @ $6.99 ea. :eek: :eek: <br /><br />Just give me back my basic engine...please!!!!
NYMINUTE
Originally posted by KaGee:<br /> We'll I did it.... bit the bullet and got Motorcraft... @ $5.95 ea.!! :eek: <br /><br />Now to find the boots... NAPA said they are available via Special order @ $6.99 ea. :eek: :eek: <br /><br />Just give me back my basic engine...please!!!!
Not likely KaGee, those greedy CEO's are on a misssion to empty the Americans pockets. $6.99 each........Self Edit! :mad:
