what starter do i need? CW or CCW?
james2222
i have a chevy motor with a pleasurecraft bell housing. i need a new starter and dont know which one i need. the when facing the motor from the front the crank turns clockwise. the starter comes in from the rear of the bellhousing. does the starter need to turn CW or CCW? any comments would be greatly appreciated. i just want to get back on the water!
zbnutcase
Re: what starter do i need? CW or CCW?
You need a starter that turns ccw as viewed from the drive end Sierra 18-5908 or 18-5902 reman 'nutcase
Bt Doctur
If the motor is a standard rotation using a aft entry(bell housing type),you need a reverse-rotation starter
If the motor is a reverse-rotation with aft entry, you need a standard rotation starter
