I have 1994 volvo penta 4.3 and am curious what temp should I be running. My gauge center mark is 180 degrees and when I first drive around its at a constant 200 degrees and after running around 25-30 mph for about a mile it will go up to 220 and sometimes will hit the max on gauge which is 240 degrees. I have a brand new water pump that I installed a year ago so I know it's not a problem. Is this normal or is something wrong? Also when I replaced the water pump I'm pretty sure I found all the impeller pieces.
