what to do?
bullredd
Hello, I have a question if someone can help. I have operated larger outboards with electric ignition. My question is for this 1970 6hp Johnson outboard i have just got. I like to know the starting procedures on this outboard. It got a choke knob i can pull in and out, a twist knob from rich to lean, a side lever i would guess for forward,neutral, reverse, and of course the throttle extension in the front. I guess I would like to know what is the starting procedures and then how should the knobs set once it has started running.
bullredd
Re: what to do?
thanks Middleground for your tips. I will try to get her running once i get a gas tank and a gas line. :)
roscoe
Re: what to do?
Follow the excellent info from Middleground.<br /><br />If after adjusting mixture setting, the engine hesitates or stumbles on accelleration, you need to adjust it a little richer.
