tfbrown1270
- Sep 5, 2003
- 202
I traded my 1989 Force 85 hp (Piece of junk) in on a 92 Johnson 90 hp; the shop I deal with here is rebuilding it for me, they sent the block out and It came back .040 (40 thou) oversize.
They are putting in new pistons, rings, rods but are reusing the crank. They said that it was fine.
They tell me that some kind of line or tube feeding the right bank of pistons was pinched. This decreased fuel flow and resulted in some piston wear.
I examined the bores before they were done and noted some "chatter" marks on the right bottom cylinder below the exhaust port and some fine scrapes on three of the cylinder walls.
In order to get all the damage out they machined all .040 over.
Will this will result in more displacement and more power...yes or just wishful thinking.
My primary concern is that so much material came off the cylinder walls. Will this make them more prone to problems because there is less material between the piston and the water jacket?
What else should I be looking for them to do?...
They have said they are going to install a new VRO improved pump not the old one; and they are giving me a one years warranty on their work.
Thanks for any thoughts.
