What type of spark plug?
crocket104
I have a 1969 Merc 110, 9.8 hp. Could anybody tell what type of spark plugs I should use and what the gap setting setting should be? Another question I have is, "How do I put the key that goes into the impeller, between the shaft and the impeller, that makes the impeller turn? :confused: Any help would be appreciated. Thank You :)
greasemonkeyozi
Re: What type of spark plug?
Spark plugs on a boat motor has to be the exact ones the manual calls for with the right gap, and heat range. If you dont have a manual, do like I do, call the dealership, ask for the parts department and the parts clerk will pull up all that stuff on his computer.
