What will this prop fit?
bcliquidforce
I have a Quicksilver Stainless prop part no. 48-72762-19.
It was on a Mercury outboard in line 6 150hp from about 1976 that I owned, but it was too much prop for the boat so got very little use and is still in very good condition. It's been sitting around my house since I sold that boat about 15 years ago.
I'd like to sell it but when I put it on Ebay or whatever, I'd like to put in the description what it will fit. I thought it would not fit merc V6 outboards but I see they have the same number of splines. Also Force might be a possibility.
Any insight would be helpful,
Thanks,
Brian
steelespike
Re: What will this prop fit?
Someone should be along with more specific info.
You probably realize the 19 stands for the pitch,the most important number.
in the meantime That prop may also fit some I/O applications.
If you look up props here for your 76 150 note a part number and then look up other
similar sized applications look for matching numbers.
Some of the last Forces used Merc. gear cases. Maybe 95 on?
Thanks,
Brian
Ayuh,.... It fits Merc Outboards with the 4.25" mid-sized gear case....
The V6 Outboards, 'n all the I/Os run 4.75" gear cases...
